llile
- Joined
- Dec 18, 2010
- Messages
- 457
YOW! A warning for all who work on batteries:
You are working on a (hopefully) low voltage high current power source. (Or if you are on a 300V Leaf battery, you are working on a high voltage high power source).
You probably have metal tools, a metal soldering iron, and work on a bench that is likely covered with little globs of solder and bits of wire. Any of these conductors (including the roll of solder you are using) can get across two live busbars when you are building a battery, and ka-POW! If your BMS is anywhere in this high current path, then Ka-POW means you can play taps for the BMS. Done it more than once.
Ways to mitigate this risk of sparks include: Insulate the other end of any loose wire. When I put the positive wire on the positive bus, it already has a bit of heat shrink on the other end, so that loose end can't wave around and touch something. Keep themetal tools off the bench unless they are in your hand an in use. Use insulated tools, like screwdrivers with insulation all the way down the shaft. You can make one with electrical tape. But this won't work for your soldering iron. Keep the bench clean of any stray bits of conductors. Use a nonconductive bench (duh!). Don't hook up the BMS sense wires when they are connected to the BMS, nor when the BMS is connected to anything else. Make the heavy BMS connections last. Double check the BMS sense wires visually, and once again with a voltmeter. They should test the correct voltage in sequence - 3.9, 7.8, etc etc.
I'm always wearing glasses or safety glasses in the shop, as required. Regular specs for soldering, wraparound safety glasses for almost anything else. Whenever I go in the shop without specs, I'll get something in my eye straightaway, it never fails. Should never solder without some kind of safety glasses, a hot solder ball in the eye is no fun. Don't ask me how I know this.
