MitchJi
Hi,
Completely nuts, wildly impractical, and awesome design/implementation :
http://www.nilsferber.de/ex.html
Check the drive:
Development described here:
http://www.nilsferber.de/ex_process.html
Screwdriver-powered vehicle "EX"
Using two 18-volt-screwdrivers as engines, the "EX" accelerates its driver up to 30 km/h.
Excentricity is defined as a deviation from what is ordinary or customary. To match this definition we couln´t just modify an existing vehicle but had to start designing something new from scratch. The result is a completely new driving concept: The driver lies headlong on his three-wheeled vehicle and accelerates the "EX" with sprawled out arms up to 30 km/h.
Eccentrically is also how the steering works: A specially developed joint tilts the back wheel and leans the driver´s weight dynamically into the curve.
The driver controls the vehicle with brake and gas handles and by tilting the back wheel with its body.
The headlong position gives you an exiting driving experience.
Check the drive:
Steering with the spine-shaped joint is very different from holding a steering wheel or handle bar. You have to use your whole body to tilt and bend the vehicle.
After going through numerous tests and models, the joint´s individual parts were CNC milled.
Some of the custom made aluminum parts we used for the drive mechanism.
