Li Time mini LiFePO4 battery made with pouch cells. Charging? Voltage measurement?
zacksc
California, Bay Area, USA
I am thinking about getting a LiFePO4 battery from a company called Li Time (I think it used to be called ampere time). The specific battery is the 12.8 V, 100 Ah, 1280 Wh mini. It’s a bit smaller than their regular battery of the same capacity, and it’s made with pouch cells. Does anyone have any familiarity with this company. Advice is welcome.
Also, this is my first battery of this chemistry, and I was wondering if voltage measurements with a good voltmeter after the battery has been resting will be very useful for inferring the percentage state of charge? (I find that voltage measurements are really useful for my lithium ion batteries, using a table that I interpolated from a Grin simulator.)
My third question is, what’s a pretty good, but somewhat inexpensive, charger for this. I can probably just charge overnight so 10 or 20 A would be plenty
LiFePO4 has a fairly flat charge/discharge (SoC) curve (google will find you charts that make this easy to see) so it is hard to tell exactly what SoC it is at just by voltage, unless it is nearly full or nearly empty *and* all the cells are matched characteristics so they are always "balanced".
Never heard of the company before. (EDIT: apparently I have, and just forgot:
Can't tell you much about the battery itself without a link to the specific one you're considering, but a quick google finds various sales pages for them with customer reviews that include what seem like serious customer-service/warranty problems in the quick glance I did thru them for a few seconds.
I don't know any really inexpensive medium current chargers personally, but I'm sure there are some. If it has a proper BMS that correctly disconnects the pack from the charger when it is full, then you can use an LED PSU like the Meanwell HLG series. If it doesn't disconnect then you should use a charger that has a built in shutoff once current drops below a certain limit (most chargers do this, though almost none specify the limit).
Assuming a correctly-designed BMS, depending on the full charge voltage of your pack, you may be able to use either the HLG-240H-15A or -20A for 15A oe 12A max; higher wattage versions of those are available for higher currents.
A YouTuber called Will Prowse has reviewed them several times and likes them. He's tested and cut them up (along with many others). Knowledgeable info.
Take a look at battery hookup it's in the USA so cheaper shipping I would assume in a lot of batteries for solar powered units and they are branching out they even have a place in California and I guess other drop off States.
For charging your 12.8V, 100Ah LiFePO4 battery, you’ll need a charger that matches the battery’s voltage and can provide adequate current. Given that you’re looking for a charger in the 10-20A range for overnight charging, I can recommend looking for chargers that specifically support LiFePO4 batteries to ensure proper charging algorithms are used.
One option to consider is a charger that I have found reliable and reasonably priced, which is the 14.6V 10A LiFePO4 charger. It’s suitable for overnight charging and ensures your battery is charged safely and efficiently. You can find more details about this charger here.
