https://endless-sphere.com/forums/viewtopic.php?f=10&t=112357
I made a few posts on a build thread a few weeks ago. I wasn’t aware we had a battery tech. thread, my apologies for polluting the pages up!
Anyways, I’ve run into some trouble while connecting 24 LifePo4 cells in series. They discharge at 100a continuous and they do not have screw tabs. They have some thick, metal that nickel can easily spot weld to.
I purchased 0.15mm (thick) x 9.5mm (wide) copper strips from eBay, cuttable lengths. I looked at copper strip ampacity tables and found I need more volume of Cu than what I have already begun to mount on my tabs. I originally referenced a source that made me believe what I was mounting would be sufficient. Currently I have 4 of my strips (mentioned above) stacked tall. Each strip is roughly 50mm in length.
Given what I just mentioned, the cross-sectional area of the copper is 9.5mm x 0.6mm = 5.7mm^2 at 50mm length. From what I referenced, this is not nearly enough to handle 100a and maintain a safe temperature for the batteries. Am I correct? I have struggled with this for a little bit now and became impatient when spot welding a few of these bars on the tabs.
I have only made 6 connections with this copper volume and believe I need to up it to at least 15mm^2 of cross-sectional area. I have also done the mounting unorthodox and possibly unsafe. What I did was I laid the bars flat, took nickel strips over the top and spot welded either side to the tab. It seems very, very sturdy yet the copper is not welded itself to the tab.
Can someone help me out. I can provide pictures to what I have done thus far.
Joe
Joe
