I would think the 60 volt controller will have different fets and caps compared to the 100 volt stuff in the 72 volt units.
The speed jumper is one of the wire sets coming out of the controller.
There are more options to learn about with these boards.
This one has a touch of throttle lag that I do not care for.
When I connected the self learn cable the bike took off on it`s own till it tipped over and started spinning in a circle leaving a black arc on the carpet.
Here is a partial pic of the board with the hall and throttle wires removed.
There are a handful of other connectors that come with this controller
Speed hi or low 3 wires Yellow to lo pad
Dark blue to hi pad
Black to ground
Phase cable 2 wires Red to P+ on board
Black to ground
Anti theft cable 3 wires Red to vcc pad
Blue to FD- pad
Green to Yellow phase wire pad
Lock cable 1 wire Red to vcc pad on / off switch
Self study 2 wires both off white one to pad xx the other to ground
Cruise 2 wires both Grey one to pad xh the other to ground
E ABS 2 Dark Blue wires one to ebs pad the other to ground
There is also an EBS jumper pad that might need to be shorted to activate ebs?
Brake low cable 2 wires brown to pad BL
black to ground
Brake hi cable 1 wire Yellow to pad BH
A Green wire with a bullet connector goes to pad SD1
