Is this the proper start on an elbows-in build. I can get the pattern but I never know if I start it off properly.
I made sure that the spoke started off next to the valve.
I made sure the spoke angled away from the valve hole so you can air it up easily without having to fight for the pump valve to be put on the tube valve.
One mistake I made, is I did not use the Boiled Linseed Oil I have for spoke prep.
The hub is a Leaf 1500w 35h, in a brand new DM24 rim 26", has new spokes from local bike store.
You can see its the gear side is facing up and I think I have the spokes in their proper rim holes. Grintech spoke calc says they are off 0.5mm offset. To my eyes its barely noticeable.
The bike I bought on sale for 360us from l.b.s. its an entry level bike with Tourney components but has 29x2.25 with lots of room for a wider tire. I can fit a good fat index finger all around the tread. My guess is I can fit a 29 x 2.40 or 2.50 tire.
The picture shows the top of the hub being the drive side (ds) , with the spokes on the ds flange going to what I think is the proper side for the spoke hole on the rim.
