zukster
Has anyone tried one of these?
I was going to build a 48V Konion Water bottle pack myself but I noticed this from ConhisMotor.com at 234 or after shipping 312. Maybe cheaper if you buy two. I was going to build one myself as I was having difficulty finding a water bottle pack greater than 36V previously. It uses the common Cell Size 18650 and says the cells are 2AH, so likely 2100 mAH LiMn 18650 cells? So at 39 cells, that works out to about 7 dollars a cell, but for something ready to go + charger + BMS. If cells turn out to be junk I can source some Konian 2100/2250's to stuff in instead.
Before comments come in, the discharge rates are fine for my KU63 bmsbattery.com controller and Cute 100 hub motor, and the low AH is fine for travel needs.
http://www.conhismotor.com/ProductShow.asp?id=279
Specification:
Battery Model 48V 6Ah
Nominal Capacity (AH) 6ah
Nominal Voltage (V) 48V
Source Resistance (mΩ)about 40
Cell Specification 3.7V 2AH
Cell Combination 3-parallel 13-series
Cell Size 18650
Cell Quantity (parallel*series) 39
Discharge Cutoff Voltage (V) 42 +/- 1V
Charge Cutoff Voltage (V) 54.6V
Rated Discharge Current (A) 12A
Instantaneous Maximum Discharge Current (A) 20A
Maximum Continuous Discharge Current (A) 12A
Maximum Continuous Charge Current (A) 5
Charge Mode CC/CV
Standard Charge Current (A) 2A
Charge Time under Standard Charge Current 3.6
Fast Charge Current (A) 5A
Charge Time under Fast Charge Current 1.5
Charge Temperature Range -20 - 60 ℃
Discharge Temperature Range -20 - 60 ℃
Battery Size Length: 400mm
Diameter: 102mm
Battery Net Weight 3kgs
Battery Gross Weight 4.5kgs
Specification:
Cell Size 18650
Charge Mode CC/CV
Diameter: 102mm
