Jay64
I am learning a ton on this thread. Thanks guys! I think the Agni Motor is 4000 rpm max.
I think you would be fine if you used heavier than stock weights. That isn't to much different than the rpm most scooters run at with stock weights. You might have better luck with a maxi scooter. A 50cc scooter wouldn't do much more than 40mph at 4,000 rpm but my piaggio bv250 would probably do about 75 mph at 4,000 rpm with heavy weights. Maybe more than that. With the stock weights I could cruise at 85mph with a low rpm but I put in lighter weights for better accelleration. I can beat most harleys to 60mph now but I top out at about eighty.Jay64 said:I am learning a ton on this thread. Thanks guys! I think the Agni Motor is 4000 rpm max.
maydaverave said:I think you would be fine if you used heavier than stock weights. That isn't to much different than the rpm most scooters run at with stock weights. You might have better luck with a maxi scooter. A 50cc scooter wouldn't do much more than 40mph at 4,000 rpm but my piaggio bv250 would probably do about 75 mph at 4,000 rpm with heavy weights. Maybe more than that. With the stock weights I could cruise at 85mph with a low rpm but I put in lighter weights for better accelleration. I can beat most harleys to 60mph now but I top out at about eighty.Jay64 said:I am learning a ton on this thread. Thanks guys! I think the Agni Motor is 4000 rpm max.
Robomaniac said:Hello gwhy!
Did you added more epoxy glue on your magnet of your motor? I recently got a motor from hobbyking and people said to be carefull with the magnet because some user had magnet falling off.
I took mine appart and did not trust the manufacturing so I will add more glue to be 100% sure they won't come off.
I would recommend that you have a look and glue down the magnet. Some people say that they did improve on magnet glue but I don't trust a 99$ motor.
gwhy! said:Hi Jay,
A outrunner with the biggest power output for a very reasonable price is http://www.hobbycity.com/hobbyking/...0-100-A_180Kv_Brushless_Outrunner_(eq:_70-55) Produces 7kw at 44v, This is slightly larger than the one i'm using ( mine is only 6kw )
gwhy! said:it draws a fair bit of no load current so it tends to get warm.
Malcolm said:Like others have said it's great to see someone experimenting with a scooter conversion. I've been tempted a few times but was put off by the fact I don't know much about scooters, particularly the details of the CVT drive and how it would work with an electric motor. After seeing your excellent photos it's all a lot clearer and I've already started scouting locally for dead scooters Any recommendations gwhy? I'm looking for a model that's well-built and popular so that I can get spares easily. The Peugeot Speedfight seems fairly common?
The RC motors seem an ideal choice as it looks as if it would be fairly easy to mount one in place of the piston and run a 1:1 drive to the crankshaft as you suggested early on. The efficiency may not be brilliant, but the low voltage means all you need is four 12V lead acid batteries plus a cheap motor and controller for a relatively inexpensive conversion.
By the way, whereabouts are you in the UK gwhy?
Jay64 said:One probably I am having is there are no markings at all on the scoot. Not only do I not know the model, but I don'tt even know the make.
fizzit said:I've been wondering: is it more economical and easy to do this, or take one of those underpowered electric scooters with brushless hubs and overvolt them?
gwhy! said:Jay64 said:wait for it... a massive.... top speed of...... 15MPH :lol:
Robomaniac said:gwhy! said:Jay64 said:wait for it... a massive.... top speed of...... 15MPH :lol:
Like you said earlier, you don't have good battery, you said you have voltage drop. The moment you get good battery you should be able to get better speed. (I hope!)
I hope you will get more then 30Mph, if you do, then I will make my own scooter convertion like you
vanilla ice said:Heh, this is the opposite problem to what most people worry about. Too little kv. Much easier problem to fix than the too much kv problem for sure!
Jay64 said:My main question is: was it going 20 mph UP the hill or DOWN the hill? :lol:
