Hey guys! I'm Brandon from Colorado and I'm looking to do my first EV conversion. Before jumping in the deep end on a car, I am looking to convert my dad's 82 Honda GoldWing to electric. I have done some research, but I can only go so far on my own. Hoping some of the great experience on this forum will help me to hone in my design.
I'm looking to use it to go to work about 40 miles round trip (can charge at work if need be), 80% highway 75mph speed limit. Will probably never take passengers, so probably me (250 fat pounds) + 50-lbs at most. Regen would be a plus, but not required. Don't have a specific budget, but figuring it will be around $5-6k all in. Here's what I have so far:
Bike: 1982 Honda GoldWing GL1100, stock weight 595-lbs, deiced, 357-lbs. Water cooled. Shaft drive with 3.1:1 final gear.
Battery: 2x Chevy Volt 48V batteries in series for 96V, and 45Ah 2.1kW (Gen1) or 52Ah 2.5kW (Gen2). The size and shape of one battery is almost exactly the same size as a single head of the original 1100, so I will be able to 'duplicate' the look and feel of the engine with the batteries sticking out the side. The batteries will be protected by the original crash bars and a custom built enclosure. With a little creative engineering, I might be able to squeeze in another 1-2x 24V 1kW (Gen1) batteries for a 120V 3S or 72V 2S2P configuration. All these batteries are designed to be liquid cooled, but could be modified for air cooling. Each 48V battery weighs 45-lbs (Gen1) or 36.5-lbs (Gen2) and 24V Gen1 batteries are 21-lbs.
Motor: This is where I really need help. I am considering the ME1616 if I decide to utilize the bike's liquid cooling, or the ME1507 if not. I am having a difficult time finding consistent specs and available models (1304 or 1302?) for Motenergy motors. I see some lower tiered motors, but not sure if they will have enough power. I have also just started reading about Zero motors, but don't know much about them or where to get them.
Electronics: One nice feature of the GL1100 is that the visible gas tank is just a cover with the real tank underneath, so I have quite a bit of space to mount my controllers, chargers, etc in the gas tank area without much modification. Obviously, most of this will be decided by the motor and battery, so not too worried about it at the moment.
Appreciate any input you guys have for me, even if it's just to tell me I'm crazy and should take up basket weaving. Looking forward to hearing from everyone!
