dnmun
1 PW
i do not use these pads. i just put them in compression and leave them alone between the end plates.
granolaboy said:I've been going through this document:
https://www.buya123products.com/uploads/vipcase/b24d4f5b63934c59d43e93b3bb4db60a.pdf
Forgive me if this was already covered in this thread, but I can't find it. The doc mentions:
Compliant Pads Between Cells
To Maintain proper cell support and account for expansion during the charge and discharge cycles, A123 uses a compliant pad between cells.
I'm wondering what makes for a "compliant pad" and what a DIY'er could use...
The only place I can find aluminum referenced in the document is in relation to extracting heat out, not compression.granolaboy said:The document states that they use aluminum plates, since they are excellent thermal conductors.
I'm just passing on the information given in the document, should hope the professionals involved in producing the report, knew what they were doing.granolaboy said:So you are saying I should find some of this poron stuff? I was thinking of using some aluminum flashing from home depot...
arkmundi said:Certainly has me thinking again on best practices for battery pack construction using these cells. Part of a best practices approach would need to consider initial inspection, testing acceptance and/or rejection of cells, etc. Then how to go about making a pack with cell longevity in mind.
