999zip999
100 TW
my problem is under vacuum and water boils under my vacuum at 29 ATMs same as LFP the water a steal boil under the same vacuum even in a foil pouch. If it boils water cold, can it broil electotolight in it's pouch.
Thanks. There's one small nuisance in my current eBiking operation. I have a Smart Charger from batteryspace.com for charging. I've gotten into the habit of getting back home, socketing my two celllogs on, noting the voltage of each of the 16 cells, plugging the charger in and waiting till full charge.wb9k said:However, I've had several cell scientists and engineers tell me that A123 cells are absolutely plating Li if the terminal voltage is held (C.V.'d) above 3.60V after charge current drops off. They "are rated" to go as high as 3.8V for up to 10 seconds at a time, at high charge rates---as long as they settle below 3.6 you're considered to be OK.
thanks for the suggestion, but I don't think so. these are new cells and the at-near-full-charge characteristics of the various cells in the pack emerged from the get-go. no bms. no detectable self discharging. just a few cells that want to charge up faster than the others, so reach 3.62v first.dnmun said:the reason one cell goes high like that is because the other cells in the pack are self discharging and over time their voltage drops during each cycle which forces the high cell higher to fill in the voltage from the charger....
Exactly. Its just been a few times when I left the charging unattended and came back to find the smart charger had stopped the charge cycle and my celllogs were beeping that I found those cells had settled 3.65<SOC<3.70. That scenario is the worrisome one per wb9k. Question is what are the symptoms of cells that have begun to plate-out? Self discharge as dnum suggests? A lower than expected voltage? A higher than expected voltage? An as expected voltage that drops lower than expected during use & discharge?999zip999 said:They charge to 3.65v but settle to 3.5v ( or lower ) "over in short time, right ark ? I don't worry of 3.41v to 3.53v on my cells as I find 3.45v as 96% and above 3.5v is un necessary. But it will it 3.8v fast, but unhooked will drop down to 3.6v as I don't think there any storage room in the cell for it.
actually that's what the guy i bought it off said to me, it was the BMS and testing the cells i found them not recoverable from close to zero volts.whatever said:thats interesting it was the end cells, I also had the positive end cell fail twice, I thought it was due to lack of compression,
but there might be something else going on, I wasn't using bms, I was charging 16s pack as two 8s packs, but connected as 16s whilst being used.
Since the packs are vacuum sealed the internals would have quite a large pressure on them from the atmosphere, both the cells that failed on my pack went 'soft', I'm wondering if internal release of gas is a factor of cells going from 'hard' to 'soft'.
arkmundi said:Exactly. Its just been a few times when I left the charging unattended and came back to find the smart charger had stopped the charge cycle and my celllogs were beeping that I found those cells had settled 3.65<SOC<3.70. That scenario is the worrisome one per wb9k. Question is what are the symptoms of cells that have begun to plate-out? Self discharge as dnum suggests? A lower than expected voltage? A higher than expected voltage? An as expected voltage that drops lower than expected during use & discharge?999zip999 said:They charge to 3.65v but settle to 3.5v ( or lower ) "over in short time, right ark ? I don't worry of 3.41v to 3.53v on my cells as I find 3.45v as 96% and above 3.5v is un necessary. But it will it 3.8v fast, but unhooked will drop down to 3.6v as I don't think there any storage room in the cell for it.
miro13car said:Because this thread is about A123 20Ah pouch....
I cant recommend enough this PDF document from A123.
What is surprising to me is how A123 rate "nominal capacity" :
look at page 64 APPENDIX A:
19,5 Ah nominal capacity at 6 Amps discharge???? - THATS NOT EVEN 0.5C !!!
Silly me, all this time I thought A123 pouches were rated at 1C discharge!!
I was wrong.
This rating makes my Victpower cells even better, I tested them at 1C SOLID on CBA and literally all 20 cells delivered more than 19Ah , and six delivered even 19,5Ah.
miro13car said:I don't know what "logic" you talk about???
A123 document says it clear :
A123 20Ah nominal capacity 19.5Ah at 6 Amps discharge only.
1C is 20Amps, 0.5C is 10Amps
At just 6 A discharge curve must be really flat.
I just bring to attention what is in PDF document.
Thanks, appreciate the explanation. So, my pack exhibits an early "healthy" life, with certain charge & discharge voltage characteristics, from which it departs as it ages, and that departure is unfortunately associated with a loss of capacity. Which makes sense, because in my situation, with the charger I'm using, its exhibited by cell voltage >3.65 before the charger believes the pack as a whole should be fully charged. And I'm right to just pull the plug on it when my celllogs beep.wb9k said:I would also be concerned if cells were settling to rest above 3.65 Volts.. Capacity loss is caused because Lithium that was previously available for "cycling" within the cells to store electric charge is now permanently plated onto the cathode. ....
Elevated resistance across the cell means that voltage will sag more under the same load than it did when the cell was healthier. Conversely, voltage will rise higher with the same amount of applied charge current than it did when it was healthier....
miro, he means you've come to the wrong set of conclusions. Begging your pardon, but you have. A123 cells in my experience deliver on their promise of very high C-rates or as wb9k says "instantaneous power." I am quite confident that I can get 100 amps continuous from my packs, which is at least 5C, not that my controller will pull that. When I get around to concluding what controller I want to match to the MXUS 3000w, I will be pulling that, from a 72V pack. Certain.miro13car said:I don't know what "logic" you talk about???
arkmundi said:http://endless-sphere.com/forums/viewtopic.php?f=14&t=52244&start=200#p1004360
I'm not yet experiencing any noticeable sag on discharge. Cells all seem to settle in a 3.5v<SOC<3.3v range and within ~0.05v of one another. Will continue on. Regards.
miro13car said:I didn't come to any conclusion , simply brought to attention.
I am using A123 pouches on my 2 bikes, I know what are capable of.
was surprised A123 would not rate capacity at 1C discharge,
but let us have this back and for maybe more members will join discussion.
dnmun said:... needed for 3.60/cell....
dnmun said:i don't like the auto shutoff chargers because they don't allow the balancing current to flow long enuff to balance the battery.
if you set the charger voltage to just a little above the 57.6V needed for 3.60/cell and let the BMS balance it then the battery can continue running on the balancing current and eventually they all reach the same state of charge. there is little chance of them overcharging above the 3.60V level then. of course i charge higher so they are always over 3.61 or so but i usually time it out so i can unplug from the charger and go.
anyway that's what i like about balancing networks on the BMS. it can keep them all close so you don't have some that are high and some low.
Compliant Pads Between Cells
To Maintain proper cell support and account for expansion during the charge and discharge cycles, A123 uses a compliant pad between cells.
