jmamcarson
100 µW
- Joined
- May 30, 2019
- Messages
- 8
I'm building up an e-bike based on an SW900 display, generic cheap Chinese controller and a 350w 36v motor overvolted to 48v.
In my various dealings with this controller/display I have fried the headlight transistor and I think either I have broken the current limiting of the controller or it never worked in the first place. Adjusting the P14 setting does nothing for the current limiting.
The motor draws high peaks of up to 1100w (instantaneous) when accelerating hard. I'm looking to find a cheap current limiter in order to bring the motor down to instant peaks of 350w-700w.
With my bike I am aiming for high efficiency as it will have to travel 35km everyday on a 48v 10ah battery. completing each leg of the journey in around 45min so average speed of only 23km/hr but including stops its closer to 30km/hr. I am also aiming to be able to make the trip without pedaling, I will pedal but I just want the option (in case I'm feeling lazy). So the high peaks are obviously not in line with a high efficiency hence why I am looking for a current limiter. If anyone has any other tips for increasing efficiency let me know
A quick search of eBay and I found cheap DC motor drivers. Could I put a properly rated DC motor driver in series with the battery and successfully limit the current? would the PWM signal mess with the controller? How would limiting the current affect the voltage to the controller? As this circuit would introduce extra losses would it be worth being able to switch it inline/out of line whilst riding so it can only be active when needed?
