I saw a 2021 bicycle at the local bicycle store in the size I require (XXL) but its a 29" which I dont know if that's good or not in terms of hub motors. It's not the best spec's but the price is right and its in stock. Tourney rear der, Atlus shifters, hydraulic Tektro 275 oil brakes not what I want I'd prefer cable, probably $100 premium on the bottom line. Has straight 1-1/8 steer tube which I like I guess, I cant ever see myself buying a $250+ fork. Entry level bikes won't have the best fork, its a XCE which is probably lower or on par with the XCT(Lowest) but then theres the XCM(Medium) XCR(higher but still not that great), V2, V3. Battery will go in triangle, and I don't do well with full suspension, I'm really fat at 330lbs.
For the bike mentioned, I am just wondering about the fork, whats 46/42mm offset mean
it says - Fork: SR Suntour XCE 28, coil spring, preload, 46/42 mm offset for 29" wheel, 100 mm QR, 100 mm travel
What does 46/42 mm offset for 29" mean?
When I was in the store, the tires looked wider, I'm not used to 29", I always ride 26'ers.
The Trek website specs say Bontrager XR2 Comp, wire bead, 30 tpi, 29x2.00''
The 2.00" tires is a real turn off seeing that in the specs now, and for the price I could just buy a used bike online classified but non come in XXL, I really do want plus sized tires, 2.50-2.80", and probably closer to 2.50". I've ridden 3.0" and its still fat tire status IMO, not "plus" status though I don't know officially. So what are my options? I figure cobble together something, front hub motor, HPC had a BMC but they have so many hubs, the one I saw was the cheapest, so probably 500W, geared, + my weight = broken gears, over heated so no good. MAC can handle more power, 1500W constantly from what I gather. Add in statorade and probably good to go right?
I've been looking very frequently for a bicycle to buy. Having a 1x7 or 1x8 would be adequate but not enough, but if I'm going to spend money on new, I'd want 3x7/8/9. I'm very tame rider, easy roads and sidewalks all the time, limited and easy single track trails once a week. I ride everyday, retired. I'd like a climbing gear 22 or 24 and a cruising gear 44T, so 3x.
A hub motor in a 29" wheel is a good idea or no, more speed that takes longer to get up to speed depending on the motor kv and will heat up if too many hills or steep stuff. That's why I am again hesitant. Don't really know which way to go, don't require mid drive, so hub it is. Geared or dd, mac would be an option.
26" with 2.50" plus tires is what I am really after, that can fit up to 2.80" I haven't run across any on my searches. Tires are sure available. With the 29" or 27.5" framed bikes with plus tires could just swap in 26" but then frame geometry maybe compromised. Fat bike with relaced wheels to fit rim suitable for tire sizes Im after could be an option too. Lots of bicycle shaped object fat bikes for cheap. My time is up for the computer at the library, wish I could format the post better for clearer idea. But yeah, 100% want 26x2.50 with ability to fit 2.80. Off to google search I go.
