John Bozi
pendragon8000 said:lolDOUBLE TRIPPLE WHAMY, FROCK ME
iwouldn't worry too mucha bout the controller getting hot. just check it after you go slow up a hill if you cover it. that will be the conditions for most current draw and least cooling. if you can hold your hand on it then its ok.
I dare say that is more than 500watts , maby 500watts continuos rated and 750/1k up hills/off the line. check the motor heat periodically after going up hills. if its quiet hot to touch(uncomfortable to hold hand on it) on the outside its probly at its limit thermaly inside.
sounds like you were having fun there
Yeah I let a bit rip on swearing but I was just blown away by how great the ride was.
On the rear hub I was confused that it said 1000w. I think you are right about the continuous rating.
I had a lot of chain drops on it, in the past as a mtb bike and now too. I've been thinking of putting the biggest widgit - I think 32 tooth chainguide solution and get rid of the crappy front deraileur. Granny gear is the wrong speed to be keeping her in anyway.
