A bought a new battery from PSWpower and I would like to charge the battery from a batterymount mounted on the wall connected to a charger. So I can easily just put the battery on the wall when I come home and it starts to charge. I opened the to check the BMS, but it was under so many layers of paper and plastic, I didnt want to tear it all up.
So anyway is there a simple way to check if the battery uses a common charging port or not with a multimeter? I guess the battery charges thrue battery terminal in both cases? The off switch on the battery turns of the BMS?
Maybe I could quickly test the fully charged battery with a charger thats put out 55-56 volt, and see if the battery refuses to charge thru the battery terminal? As it would still keep charing then if it does not have a common port on the BMS?
