harrisonpatm
- Joined
- Aug 8, 2022
- Messages
- 858
I put this battery meter on my e-motorcycle build:
https://www.amazon.com/Battery-Capacity-Indicator-Monitors-Lead-Acid/dp/B08L8RDW17/ref=sr_1_4?crid=2G84J5SZBOV9A&keywords=72v+battery+capacity+gauge&qid=1662818320&sprefix=72v+battery+capacity+gauge%2Caps%2C97&sr=8-4
My battery is 24s LiFePO4. I read reviews for this product saying that it needs a few full charge/discharge/charge cycles to display accurate remaining battery life. Unfortunately this has not happened so far. I can say that the live voltage display is accurate, within .05V of my BMS reading. Problem is that as cheap as this meter is, it tries to reflect remaining capacity while also experiencing voltage sag during high-amp acceleration, leading to a wildly inaccurate reading. Even when not in use the percentage remaining is off. This hasn't been a dealbreaker, since I trust my BMS reading (which I have to access via my phone), I have a good idea of its range based on a couple of range tests, and I can do things like set the odometer when I charge 100%. I don't go on long excursions anyway.
Does anyone have recommendations of a battery capacity display that actually displays somewhat accurate SOC? Preferably under $50. Thanks!
