TwisterGripper
Hi all, I'm wondering if anyone knows if it is safe to test capacity of shimano BT-e8020 battery using basic watt meter tool and a resistor for load (Grin 6.8ohm 400w resistor)? not sure if I can treat this battery the same as most ebikes and just connect + and - to the main batt terminals...or will i mess something up with the proprietary BMS shimano uses? just a bit nervous to try it as I dont know if the BMS will cause issues.
Edit: using this method with a 0-100a watt meter and a 400w resistor: https://www.youtube.com/watch?v=Jc-6crET3Wo "just ride the bike" responses....well i'm looking to get a somewhat accurate measure of the remaining capacity here.
