docw009 said:Akerhange, Does your battery go into a working cradle? How does that funky XT90 adapter get used in your bike? WHat you show in your pictures makes me doubt that battery power even gets to your display.
Here's a wiring diagram someone kindly provided for the BBSHS, but I believe it matches the BBS02. FOllow the wire out of the display to where it meets the main harness. If you unplug it, the harness side will show a round connector with 5 pins, a male connector. Bummer. Female is better.
This part is not easy, because of the darn pins, but battery power and ground are available there. If your buddies at work have clip-on probes for these pins, it's an easy thing to measure, but for us folks at home with blunt probes, it takes care, as we can fry an adjacent pin if the probes slip. In any case, if it can be measures, and if battery voltage is present, then the display got whacked when you fell.
You could also look at the harness connector coming out of the motor and check there for battery voltage, but I think the motor side is also pins.
Thanks, I will take that picture to work tomorrow. However I cannot get the bike to work now
But maybe I can borrow a multimeter and measure myself somehow?
Im thinking that its not the display? Because I got it working for about 30s a few days ago. Display looked as ususal. And when turnnig the throttle on it did die. Also the display lights up 1 second now (HELLO-yellow-screen) and dies when trying the first time after the battery has been charging a while. If trying again after that, all black.
This is how the battery is mounted on the bike now. It has worked without any problems 8 months for me.
