ElectricGod said:
I went to mouser.com and looked them up. Interesting isn't it? Why out of China are they sooo cheap and yet for legit ones found in the USA, they are sooo expensive? It makes me wonder about quality.
Sorry, I didn't mean to be sarcastic or rude. I was genuinely surprized by such a high price, I didn't expect that there would be such a difference.
I can't really say if there is an actual practical gap in terms of quality, since I never tried the 65 dollar ones.
What I can say is that I'm using a few of those SSRs, one to control my furnace PID temp, a few others to control my various 3D printer heated beds (2 are controling some 200W 12V bed for small delta printers, one controls a 800x800 mm giant 220V heating bed for my big cartesian 3D printer).
So far I had no problem with them, they do PID control just fine for hours and hours so they had countless switching cycles already. They don't heat nearly as much as I was expecting, but that might be different when under continuous loads, I don't know (though, the furnace takes around 30 minutes to reach its target temp of 700 degreeC so that's around 30 minutes of 100% load).
I however did oversize them quite a bit.
Anyways, if you already have mechanical relays then you can go for it, no need to spend more money than necessary
You didn't mention which relays you'll actually be using, but if this is anything like those ones:
https://www.amazon.com/SMAKN%C2%AE-Active-Channel-Arduino-Raspberry/dp/B00VH8926C/ref=asc_df_B00VH8926C/?tag=hyprod-20&linkCode=df0&hvadid=196274408286&hvpos=1o1&hvnetw=g&hvrand=9960072305118255567&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9031350&hvtargid=pla-315539484865&psc=1
Then you should probably test them first at 9-10A.
I've used a few of these relays for various projects, and they do heat quite a bit, I wouldn't be confident to run them at 110V/10A for long. A few weeks ago I tried running 2 peltier modules with one of those relays, the peltier was drawing 6 Amps @ 12V and the relay was quite warm after 10 minutes.
Try to connect a load to one of those and test if the heat remains manageable during one or two hours, just to make sure.
