Hillhater
100 TW
jonescg said:If you are using bricks of 6s from HK, and you are paralleling them at the balance taps for more capacity, a dud cell in one brick will cause the same cell in the other brick to begin to draw down. In the end you get two bricks with one dead cell each. You can either pull both apart and replace the offending cells (PITA) or buy two new bricks (expensive).
I see what you are saying Jonescg, but if you also have a LV alarm ( or better still a LVC )on those balance leads you can avoid the dead cell propagation.
Also this would detect a single cell "internal short" defect, which could be isolated by using low value fuses ( 1A ?) in the balance leads.
( I suspect those 20g balance leads may well act as a fuse in such a situation ! )
A similar cell failure in your 3p pack would be much harder to control, possibly causing a major thermal event ?
