Hi,
First of all, I'd like to say - please hear me out. I've done some searching and have found that while some members of this forum have successfully completed such a task, it seems by and large, the overall userbase of this forum suggests against the use of li-ion 18650 cells in favor of various other chemistries, primarily LiFePO4. So I am aware that many suggest against it. That said, it looks like commercial products nearly identical to my planned pack already exist: http://www.campsolution.com/li-ionbatterymodule36v88ah288whwithpcbready40x1865010s4p.aspx
However, this is a project that I've been planning for a bit of time, and I only recently found this forum. Too bad for me.
I'm soon to be living in NYC and plan to use an E-bike as my primary mode of transport. I wanted to do this as cheaply as possible.
After looking at dozens of pre-built kits and reading reviews as well as info about different battery chemistries (it seems most commerical kits are SLA or Li-Ion), I decided that I finally had a use for the giant box of mostly working laptop batteries at work.
I traded my boss 2x2GB sticks of DDR3 memory for almost 50 li-ion laptop batteries. After looking at the ratings of the batteries and sorting them based on the cell size I expected to find inside, I found that 2200mAH cells appeared most frequently. I am waiting on my testing equipment, but I have 88 untested 2200mAH cells (more if I keep cracking open batteries). I am hoping that at least half of these will be good. Being a little hopeful, as I would like to build a pack that is 5p10s to achieve 11AH at 36-37v.
My plan was this:
1) Charge cells individually on this: http://www.batteryspace.com/smartchargerformulti37vrechargeableli-ioncellsof18650rcr123aandmorech-unli004.aspx
Cells which do not charge immediately go to the recycling bucket.
2) Once I have my cells which charge sorted out, I would like to test the capacity of each cell. I do not currently have the knowledge to test capacity, but I understand how AH are calculated and I taught myself the rest of this... so when I get there? If anyone has suggestions on this, please tell me. Thanks!
3) Wire cells in 5p groupings, using cells of same manufacturer, and if possible, cells from the same original battery. I know soldering these batteries directly is a bad idea and thermal glue gets bad reviews, so I'm still brainstorming here. Many of the cells still have tabbing attached, some do not.
4) Wire 5p groupings into 10s layout with this (or similar) PCM: http://cgi.ebay.com/PCB-PCM-36V-37V-Li-Ion-Battery-w-Equilibrium-30A-/300473778895?pt=LH_DefaultDomain_0&hash=item45f5a202cf
That's all for now. Does this make sense? I understand that li-ion is dangerous and that is why I am seeking the advice of professionals. I am merely ignorant and trying to learn, so please go easy on me.
Thank you to everyone who read and extra thanks to those who respond. Love.
My plan was this:
