If you get a temperature sensor with alarm or beeper, you cna use the beeper output to trigger a 555 timer or similar to engage a throttle cutback (change resistance inline with or parallel to the throttle), to cut power back if it overheats.
You could set a second sensor to deactivate the controller's keyswitch/ignition line once temperature rises further past a second setpoint. Or have it activate the ebrake line (as long as you don't have regen enabled).
Then use the CA to limit current and whatnot normally for the rest of it.
That'd at least get you automatic control until the CA has it as a built-in option.
