Buying bike for qs205
Jae
Ma
I'm looking to buy a bike for a qs205 conversion,trying to not spend over 300 for the bike itself.What do you guys think would a 72v triangle battery fit in this one? Or I'm open to suggestions as well,was also thinking about using a hardtail fat bike but was really hoping for full suspension.
May be an image of bicycle and text
Like
Comment
Send
QS 205 is single speed with 150mm rear drop out spacing.
It's going to be hard to find a frame that works with that outside of a Stealth Bomber, Vector Typhoon, Qulbix Q76 or some clone of one of those.
P.S. Some downhill frames have 150mm rear spacing but these won't work because they are thru axle.
A QS205 will rip that frame to shreds if you could stretch the swing arm enough for it to fit. And get the chain aligned properly. And if you could find somewhere to mount the battery and controller. Also what do you intend to do about the rear brake?
I decided to get a Mongoose Malus fat bike and I'm picking it up this afternoon.Should be fine i think with a steel frame,disc brakes and a bigger triangle.
