Dui ni shuo de dui
Hello guys,
I recently started to have a weird issue with my motorbike. Sometimes, when running at high speeds, the bike will suddently have what feels like a big burst of regen braking, then the controller would cutoff. This happens when I have the throttle either wide opened or slightly accelerating while already at 60+ mph, it's not supposed to be in regen mode.
So that's a bit dangerous, obviously, because the wheel can lock up for a brief moment, while it wasn't expected at all to do so.
This is fairly new and seem to have started occuring recently, probably after I've set a higher current for the flux weakening.
I'm a bit puzzled as to what could be the cause.
I'm pretty sure it is not a motor phase short, because it happens quite rarely and also because the controller cuts off from overcurrent protection (so that means that the energy is somehow coming back to it). But maybe I miss something here.
My guess would be that maybe the flux weakening is messing up with the hall sensors, causing them to send wrong information to the controller and then messing out the timing. Is that even possible?
Did any one have this issue before or could provide any plausible explanation on what's going on?
Thanks a lot in advance!
