MrDude_1 said:So what is the absolute max power of this little controller once potted? Is it any higher or lower?
I don't think that the potting is either here or there in terms of the power capability. Pretty much the entire thermal path is through the aluminum heatsinks, so it's the heat capacity of that which will determine the time it takes before the controller goes into thermal rollback, and it's the ability to shed heat from that (via passing airflow or attachment to a larger metal surface like the bike frame) which will determine the steady state continuous phase current output at thermal rollback.
Both figures could be increased significantly by simply bolting the controller to a larger finned aluminum heatsink block, and we're trying to make it easy for people to do that if they are running high phase amps all the time. We will at some point run some proper lab tests in order to quantify the operating envelope under different conditions at different wind speeds, but it's an elaborate and time consuming set of experiments to run.
For my own usage with this first prototype, riding ~40 kph with power draws from 300-1200 watts depending on the grade hill it's only ever gotten just warm to the touch.
