crossbreak
mr.electric said:The interference that damaged this motor only occurs when the motor shaft is plunged deeper into the motor. Since nothing really pushes or pulls on the motor shaft the issue did not present until the motor was driving a bike down the road.
this is what i meant with "aligning" it axially. Sometime the language barrier sucks Maybe I should have called it "shimming". In this case a LOT of shims woulds have been needed. Do I see it wrong or was the rotor aligned axially (not only radially) in one direction by the key, which you took away from the original construction?
