liveforphysics said:
Does it leave little porosity tracks in the weld along with splattering?
Or just splatter like a mofo but leave ugly globs of steel with no tiny tracks of holes in the bead?
Luke..ma main man :wink: i took a pic of a weld i did on a scrap piece of 1.6mm walled
tubing for you to checkout the first blobs is with the welder set at what it was when Snapper
welded the frame up, the second setting is what i would use to weld 5mm thick plate, hence
the big hole tried the high setting just to see what it did, it just pops and spits on correct setting
for this size wire, like when trying to weld with too fast a wire setting and too low heat (hence we
tried the high setting) as you can see almost zero penetration just a big glob of a weld, without
doubt the worst weld i have ever done... I am not as 'pro' as a couple of my mates when it comes
to welding but i can lay down a decent looking weld, i believe i have shown enough here with my
builds to support that claim, it's this wire, it's just complete rubbish! My other metal fabricator buddy
Flavio was here in the arvo, he's a boilermaker welder with also ~20 years on the job experience couldn't
do any better with this wire when i asked him to try it...
I shall try the oven today however, but unless it is at least on a par with the CIG wire welds it will be binned.
gestalt said:
jester, I can't believe that you are using gasless wire for frame building!
Yup, have used it for all my frames, if you know how to weld gassless works fine IMHO, however
i would recommend (
if you can afford to) a gas setup, gives you the option to weld
non ferrous metals, IMO too, you can get a 'prettier' flowing weld with gas setup easier
than with the gassless, just my opinion here. . If you stick with gassless though i strongly
urge you to get some anti spatter spray and/ or, heres a tip i found out only yesterday!...instead
of paying mega bucks (
or geting a mate to thieve it from their work :lol: ) you can use normal
cooking oil as anti spatter agent, the stuff in an aerosol can you spray on your fry pan before cooking
cost 1/4 the price too and doesn't stink when you weld over it haha... Cheers for the support. :wink:
dequinox said:
Although AJ doesn't have to worry about it, he's got powder coating!
Thinking of going with
this color scheme this time mate?
HAHAA you been talkin with
"J.J" my Costa Riccian pal haven't you
he seems
to think I like girlie colours for some reason
i'm starting to think its him who actually
likes these colours seeing he always has a dig at me suggesting
i use them
...painting the last bike blue was a bold enough move for me, i'm more than happy with any
shade of black
Seriousknot said:
Aussie that is truly artwork, you have an eye for curves.
If you're still looking for forks, you might think about this...
These are from a 2002 Honda CR80 Expert. Honda actually used these on a DH bike
they built, I think it was called RN01. They adapt easily to bikes and
come out being only a few pounds heavier.
Custom machined steerer tube. I have two sets of these forks.
My big brother has been desperately trying to find some triple clamp forks, was just
last Sunday i said to him some have used Honda CR80 forks on their bikes! I
have also considered it myself and haven't totally discounted it, whats stopping
me going their payday and snapping up a pair is the head tube,
i am not about
to alter this 1 1/8 head tube that i have cut from a frame
Matt.P gave to me, can't
do that ..period. Only option would be to chop the headset out, set it aside for next bike
and butcher one of the dozen older style headsets i have here. It would be a very very
last option if i can't get a set of older model Boxer (or similar) for 300-400 bucks though...
I have to watch the $$ I still need to pay for the parts Thudsters using to build the box and
bearings and wire for the motor rewind too...
Thankyou for the suggestion though
Seriousknot,
it is a very good one IMHO and good to bring to light so others unaware of the cr80 fork situation
might take advantage of this option .... Curiously, would you be interested in selling one of your sets of CR80
forks? IF so what sort of money we talking?
I received some
GREAT news from
Todd this morning
he has the wire and wind calculations done and the stator rewound with 14AWG
i think thats correct ?-->
and in comparison to the stock job wound HXT stator
This is seriously larger wire than stock, it has 6 & a 1/2 turns will give a higher kv than the stock motor
with ~double the torque! Looking in the vicinity of 180kv up from 130kv i have been told...I have the words of
my electronics genius and number 1'
got-to-guy' on anything electrical or how to handle the wiminez
Luke, ringing in my ears still,
go with the highest kv you can get away with...I had planned on buying a 180kv Turnigy
now i have one!!
hand wound with mofo size wire with quality bearings and a hardened steel
shaft!!
Thudster da man!! It will be run on a
DY NO MOM METER<--i get that right
Thud haha
Yes lads, we is getting
very serious about building a
100% reliable frock eating rc motored bike
this time round. As i said to Thudster, the sound of this baby running WOT @ 11000rpm on 66v setup
will be music to my ears! .....waaaaaaaaaaaaaaaa :: clunk:: WAAAAAAAAAAAAAA
Anyone wishing to follow the rewind and dynoing of my HXT Turnigy can do so on
this thread Thudster started
Too put Thuds work into perspective and what has been achieved i think Luke summed it uo best with this post
"For the folks that don't fully appreciate the significance of what Sir Thudly has done here, he has just turned the power capability of that motor into the power capability of two motors.
That single big HXT motor is equal to, or more powerful than the pair of big HXT motors I run on my bike.
(Which is precisely why I MUST rewind both of mine now. Maybe shoot for 260kv with double copper on each motor. )"
Wonder how confident J.J is feeling now about that 400meter run? '
Thanks for the kind words of support fellas much appreciated, shall be back with more
soon, i am tryng to think of something i can do that doesn't involve welding, i think i will checkout
Thudst CAD drawings for the
2 Speed Thudster Box and then design up a nice mounting bracket
for the seat tube.
KiM
