parabellum
Is such shock therapy even good, spraying cold water on hot winding? Can it be used on daily basis without damaging the motor?
parabellum said:Is such shock therapy even good, spraying cold water on hot winding? Can it be used on daily basis without damaging the motor?
Dunno, but compressed air might be better?cal3thousand said:parabellum said:Is such shock therapy even good, spraying cold water on hot winding? Can it be used on daily basis without damaging the motor?
I don't plan on spraying a 'hot' motor myself. It would be a spray when I get home and then running it until dry. Only on the occasion that I feel dirt ingress occurred.
Is that a bad idea?
999zip999 said:I saw Luke take grinder to cut a hole in top of a hot motor put a hose in it. Then cut a hole in the bottom to let the water out, then take it on the track ?
It was hard to understand.
liveforphysics said:The moment it was full of water, the Sevcon gave a fault for "phase winding short-circuit", and wouldn't run.
agniusm said:Bernoulli's principle.
Thanks Justin and all the posters of stuff they have tried. Hard to say for sure but it looks like fins on the outside is the route to take. Images won't repeat so go here if you dont know what Im refering to...John in CR said:I agree with AW. You don't want to cut into the magnet backing ring so close the the magnets. It's much easier to make holes in the cover.
With effective ventilation you don't need any extra heat sink to cool the motor. As Justin proved earlier in the thread, holes or slots alone are relatively ineffective. I've always used some kind of interior blades, which explains the success I've had. More recently though I added some exterior blades to a hubbie with exhaust slots only on one side, and now the motor moves a tremendous amount of air. I started with a many slot approach to keep debris out, and my thought was the material between each slot would act like a centrifugal blade. It did work and flows some air, but I'm sure less than 5 or 10cfm, which can't take much heat out with it by my calculations. That changed with the blades and I can feel so much wind off of that side of the wheel that it has to be moving hundreds of cfm through and across the outside from left to right. I tested it with smoke and it sucked smoke both inside and across the outside quite strongly even at mid hundreds of rpm. My next iteration will be just 6 larger exhaust holes with a slightly angled blade in front of each instead of just straight radial like I did here. The slight angle will be so the blade covers the hole to some extent. With a more typical hubbie there's more room between the cover and the stator, so the narrow slot cut for the blade will allow a significant amount of blade on the inside to, which will create more turbulence at the stator for better cooling. Drilling bolt holes and tapping threads allows the blades to be fit perfectly from the outside with the motor assembled. I didn't even take the motor off the bike to install my blades. I used a piece of cardboard in the slots to get the interior amount of blade just right before cutting the metal ones. :
John Bozi said:It makes sense to have "scoops" to swipe the air in even more aggressively than just having fins internally creating a simple direction.
Is the logic of the scoop to pull in the air on one side and push it out on the other side and so why?
Wouldn't it be be logical to just have them on both sides as they will only ever be scooping air in the direction of the bike is going. So for example pulling it in at the bottom of the cycle and spitting it out at the top of the cycle.
Instead of just having cuts across the whole hub just have them under the scoops.
John Bozi said:What interests me now is testing the stop and take a break vs keep going at minimum throttle as a way of cooling the motor down. Keeping that breeze flowing seems to be more advantagous even at a simple pedal cadence and if needed with a little bit of power than just stopping and waiting.
Good job. I use the same thing in my X5 although I managed to get mine pointer out wards so the air will blow from the center (cold air inlet) to the windings then out the holes around the outer diameter. NON the less its amazing how well the fans work.Cowardlyduck said:Justin/John, I did some mods with 25mm fans to my HS4065 recently that have been working well so far. I do a lot of slow off-road riding, so for these conditions the little fans really help.
For details see here: http://endless-sphere.com/forums/viewtopic.php?f=30&t=56965&start=25#p946731
I plan on doing more tests with longer real world rides and plotting the temps, but for now I managed to get this graph down in mostly controlled conditions.
For anyone else looking to do slower riding where air flow over the hub shell is not as significant (say <40kph), I would highly recommend doing a similar mod.
Cheers
Cheers
That's a good idea actually. I run 50v fully charged, so my 6 fans would run at about 8v each if I did that. That's a little slow, but still acceptable if I needed to. For now I use a small DC-DC converter which I can adjust the voltage on when needed. This way, when cruising around town I can turn the fans down for less noise, but when flogging it off-road, I can crank them up to help cool better.Arlo1 said:BTY I got 3 year warranty with my 12v fans then I run 25v (fully charged) to them I just run 4 in series and hooked pack voltage to them
My windings are not dark from over power I think. I previously sprayed a silicone based black paint all over the windings to protect them. That shot above was after attempting to wipe most of it off. I've previously put 6+KW through this motor, and shorted 2 strands on one phase to the stator. I then removed those strands, and the motor still works. See the end of this thread for details: http://endless-sphere.com/forums/viewtopic.php?f=2&t=55486icecube57 said:Those are really dark windings you probably exceeded 150C.... Many times. My last build I threw 5kw at a Magic Pie and had the thermal limiting activated on the CA and set to about 140 and after a year of abuse the windings were shiny like they came out the factory. The winding tie downs were intact and not discolored. The plastic that insulates the laminations was intact and not melted. It was a brand new motor. You my friend dont have many more lives left on this motor. If the fans werent already installed I would suggest some sprayon varnish to reinforce the enamel on the windings.
No fans in that test means just turning them off. The covers are still vented, but just at the perimeter near the windings. The point I'm making is straight venting can only help so much...add some fans and it's that much better.John Bozi said:1. does no fans mean a sealed motor or the holes are open with no fans in the way or fans are covering the holes not turned on?
It would make a big difference to the data.
No, that test was about keeping things consistent. I've had the fans running with the motor up to over 110C a number of times up steep hills. My temp gauge maxes out at 110C. It cools off very quickly, even still pushing 1+KW through it as the hill tapers off.John Bozi said:2. If you pump 5000 watts up a mountain riding slowly are you showing us that you don't get over 50 degreesC?
What temperature are the fans rated at? I can only imagine they would melt at 120Celsius....
Agreed! As mentioned, more tests planned. The point of the first test was to prove the concept.John Bozi said:We don't need fans at 50 degrees celcius so the graph and usefullness of them would be amazing at the 110-80 mark....
please!
Negative. Once I hit 40kph+ the normal air flow over the motor seems to cool better than the fans, or at least faster. The fans don't make a difference to this as they would only prevent a cross wind from flowing through the motor in one direction.John Bozi said:3. If you do both slow riding and fast riding wouldn't fans just get in the way of higher convection rate of going 50kmh?
Not much. The DC-DC converter I use maxes out at 15W. I'm running 6X 12v fans. Previous tests showed about 0.5A at 15V, so 7.5W. If anything the lower motor temps mean it is more efficient, so I use less power overall than without the fans.John Bozi said:How much battery do they take to run on a 30k trip?
Fechter, check out the other thread. Some similar suggestions have been made already.fechter said:Another approach might be to use axial fans and have return holes in the stator. This will increase total air flow, but it won't be directed through the slots as much. Heat from the windings can tranfer to the stator and get picked up there.
