izeman said:
Emmett said:
Would some low-vis transformer oil be the best thing to use?
also a good idea. but several test have shown that, as already stated several times, ATF is a very good fluid. it's very thin and is not conducting electricity. it can dissolve some plastics though. the heatshrinks used in my motor have been almost dissolved and useless. so take care!
When guys here write about "no load amp" increases, are they implying that the ATF is conducting electricity?
no. no load amps raises just because there is some resistance added as the windings have to move through the fluid. you can imagine yourself walking on land and trying to walk in a swimming pool
Thanks for the quick reply.
In that case I can ignore no load amps increase. Since it's cooling (stator to outside) that I'm after, in low speed high torque riding conditions. Also the fluid drag is not a factor for me.
FYI, Just by subjectively playing with some ATF I have in the garage, versus some soy vege oil, the vege oil actually looks/pours/stirs as though it's lower vis. I know there are many types of ATF. In any case the vis difference of ATF vs vege (soy, sunflower or peanut) oil doesn't seem like much.
You've made me wonder if vege oil has multiple advantages over ATF:
- Vege oil is guaranteed to not have additives which might conduct, such as friction modifiers containing metals like zinc, tin etc.
- Vege oil is totally safe to the polymers and seals inside the hub
- Vege oil is biodegrable so safer for the env (and me and my tire) if it leaks out.
- Vege oil has no smell or a nice smell, but ATF simply stinks.
I don't see how I can trust ATF, when it's not a dielectric fluid which can safely go inside a transformer.
My third question is still out there ... if some fluid used in the hub (say 1/4 full) was slightly conductive, then what components would be damaged first? My guess is the controller, because more amps is drawn by a mild short circuit in the motor/fluid. Assuming the controller has no safety logic.
