Rodney64
Thanks Paul. Yes putting the battery in at Chris' on Saturday. Yes thanks for the tip on the padding.
When it's going it would be good to go for a ride. I know of one fighter owner her in Perth who's keen as well.
To sit on it reminds me of an old XR 250
Installed the front brake and threaded the cable thought the frame to the rear. I need an adaptor to fit the rear brake as it a post mount.
I purchased these brakes in Perth from a bike shop and this guys keen to help.
Tomorrow back to the bike shop to discuss option for the front sprocket bleed the rear brake as I had to disconnect to tread it though the frame and cut and tighten the front headset.
The current Chrystalyte 7 speed rear will not work as the 14 tooth small sprocket doesn't clear with room for the chain to change.
With the 52 tooth front sprocket the chain has 5mm clearance from the rear swing arm. Not enough clearance.
No photos today but will take a few tomorrow at the bike shop.
Planning on finding a 11 tooth front sprocket which will give plenty of room for the change and also a good top speed.
