thriftybuilder
I have a Sevcon gen4size6 controlling an ME1616 motor. It is now working, after I found an issue with the Encoder voltage coming out of the Sevcon. I have DVT set to 5V sin/cos sensor, but the I measured the voltage between pins 26 and 15 at ~1V (spec sheet says these pins power the encoder). This obviously was not working (motor was making noise but not spinning). Voltage from pin 26 to B- (ground) was ~5.4V, so I simply connected encoder negative to B- instead of 15, and now everything is working.
So my questions are:
1. Has anyone else had encoder voltage issues between pins 26 and 15?
2. Why might pin 15 not be tied to ground? When I measured pin 15 to ground, it was ~4V, but it should be 0V.
3. Is there another relevant setting in DVT other than the obvious encoder voltage in object 0x4630?
4. Do you foresee any issues with my current wiring? Maybe noise, voltage spikes, or floating voltage.
DCF and wiring diagram attached. Disclaimer this DCF has various settings that could damage your equipment, so do not use it unless you know how to use DVT to update relevant settings, understand the risks, and you take full responsibility / liability.
