Did it ever work correctly?
If so, what happened between the time it worked and the time it did not?
If it did not ever work correctly, is it setup for your motor and system as it needs to be?
Is the "cutout" a complete loss of power, no voltage from the battery at all, or is it just not driving the motor at that moment, and if you do nothing else but let go of throttle and ease onto it again it then works normally?
Is your battery capable of supplying the necessary current it is setup to draw?
