999zip999 said:How many ah is it ? It can depend on the bms for rate of charge. Where'd you get the battery do you have a link we need to know a lot more information.
I break mine and half as to 36 volt and I charge eats 36 volt pack at 16 amps each. But most people don't run run highest quality cells. A123 and heavy. It's always a compromise.
Most are limited by their BMS which only allows 5 amp or 8 Amp.
None of the common BMS units I've seen have any kind of current limiting that PWMs the input voltage to reduce the current. Some might detect the current and shutdown the input completely if it's too high, but the ones I've worked with dont' have a shunt on the input side, only the output.flat tire said:If your BMS only allows a 5 amp charge, then you will just get 5 amps.
Need to know the Ah!rumme said:I have a 72 volt pack using Samsung 22p cells/18650 .... and my 3 amp charger is a bit to slow. What current options are there for fast chargers and would a 10 amp charger be to aggressive ?
999zip999 said:Yes ? Samsung 22p cell or 22 cells paralleled.
72V 22Ah = 11A >> 17.6A = 20s10p (200 cells)DrkAngel said:Need to know the Ah!
Samsung ICR18650-22P are rated at .5C normal charge or >> .8C rapid charge (with diminished lifespan)rumme said:I was told the battery pack is 72 volts - 26.4 AH using 22p Samsung cells.
72V 4.4Ah? = 2.2A >> 3.52A
72V 8.8Ah? = 4.4A >> 7.04A
72V 13.2Ah? = 6.6A >>10.56A
72V 17.6Ah? = 8.8A >> 14.08A
10-12 Amp charger looks ideal.rumme said:I have a 72 volt pack using Samsung 22p cells/18650 .... and my 3 amp charger is a bit to slow. What current options are there for fast chargers and would a 10 amp charger be to aggressive ?
DrkAngel said:72V 22Ah = 11A >> 17.6A = 20s10p (200 cells)DrkAngel said:Need to know the Ah!
72V 26.4Ah = ≤13.2A normal charger >> ≤21.12A rapid charger = 20s12p (240 cells) 12x 36V 4.4Ah oem packs
880-1000w charger or regulated current power supply.
2 x 48V 400w power supplies in series could supply 84V 9.5A
Requires current (Amp) mod on, at least, 1 and setting both 48V PS to 42V
See - Meanwell clone- AD488.3-400W power supply mods
What Dogman said, but do you need an opportunity charger or a home charger?dogman dan said:Fast charge naked, if you need it that fast. Bypass the bms, and ideally, undercharge by setting the charger to .05v per cell low.
I have the bigger charger from bms battery, and so far its working ok for me. I think its the 800 w. (10 amps) Kind of liking the fast charge, on a 15 ah lipo pack. So for me, no bms to worry about. Mine is the old one, from several years ago, looks like they have newer versions now at bms battery.
If you have a bms, then finish off with the slow charger when you want it balanced.
wineboyrider said:What Dogman said, but do you need an opportunity charger or a home charger?dogman dan said:Fast charge naked, if you need it that fast. Bypass the bms, and ideally, undercharge by setting the charger to .05v per cell low.
Power supply fills that function.rumme said:Was looking for a home charger that runs off 120 volt AC...I guess there aren't many inexpensive fast chargers { 6-10 amps} that will also go into trickle charge mode near the end of the charge to top off the li-ion cells ?
Yep. Constant current constant current chargers taper the charge toward the end. i currently use meanwell hlg led chargers for a 10 amp charge, but I use HK Multistar batteries.DrkAngel said:Power supply fills that function.rumme said:Was looking for a home charger that runs off 120 volt AC...I guess there aren't many inexpensive fast chargers { 6-10 amps} that will also go into trickle charge mode near the end of the charge to top off the li-ion cells ?
Many subscribe to the theory that the finishing trickle charge is detrimental to cells.
"Charger" actually shuts off slightly sooner and discontinues charge, theoretically, avoiding a type of deterioration.
