Ok, so a year later, the house is fixed up and I'm finally moved back in, and have located most of the parts for this in the stuff that was left after all the things that happened between then and now.
Since CrazyBike2 is in even worse shape now than it was last year this time hwen I was *already* about to replace it with this one, I am now working on this bike as seriously as I can.
There are going to be some frame changes, to more easily accomodate batteries, etc., within the frame. I will almost certainly be cutting the crankshaft for the pedals and widening it a lot, so that the chainline can mroe easily go around hte battery boxes inside the frame.
Those boxes will be old-style 50-cal ammocans, one of which contains an EM3EV A123 pack, bought used from Rollodo here: http://endless-sphere.com/forums/viewtopic.php?p=825399#p825399 with some of the rebuilding-funds from ES members (basically replacing the stolen-during-house-repairs LiFePO4 CammyCC pack). IIRC it nets me about 25 miles or so. The ohter contains an experimental EIG NMC pack that's a little higher voltage, which IIRC nets me about 30-35 miles or so. Then there is a third pack I could put in, much smaller, in a 7.62 ammocan, an RC LiPo pack thats about 10-15 miles worth.
So there'll be a hinged cover to allow access to get to those, on the non-chain side. But it does require widening the crankshaft so that I can actually put *both* the big packs in the central frame, and still be able to pedal if I have to for any reason. Originally I was going to keep crank width the same, and just run the chain up and around the whole frame, but that still means a circle the size of the cranks/feet that can't be used for battery/etc, due to the narrowness of disance between them. If I widen the shaft then hte cranks are farther out, too, and I won't have to worry about it.
The complication wih this is that the BB shell will have to be cut and widened too, which means it will probably warp in hte process. So...I may just use TWO BB shells end to end, and not actually weld them together more than just spots, leaving htem attached to their respective seatposts, and then weld the *seatposts) together via cross members. This solves another problem, too, though, or at least helps with it--that of "boxing" the whole core frame of the bike, to allow horizontal triangulation of the front section as well as vertical, to reduce twisting forces on the frame which cause chain misalignment, wiggle, etc., which were problems on CrazyBIke2.
So it would look more like this:
where dark green is the frame, red is steerin stuff (USS), black is tires and drivetrain (motor/nuvinci), purple is seat, pink is fork and swingarm, etc. Still using hte motorcycle shock on the rear, probalby the white forks just above up front.
Cargo pods or racks or whatever can go on the frame rails as needed. Will have a truck-type ball-hitch for the trailer at the back end of hte frame behind the wheel.
Am also open for suggestions as to what would be better than the above, given the limitations of what I need this for, and what I have here to make it out of, etc.
Most likely it'll end up with a 24" or 26" front wheel with a small geared hubmotor in it (like the fusin "1000w" off delta tripper) as an emergency backup motor, though I'm not sure yet. I don't want to put a motor in the back wheel itself ccuz that's part of what has destroyed so many wheels on crazybike2--the extra weight plus no suspension, though this one *will* have rear suspension.
Not sure about the USS either, cuz I'm used to the regular handlebars and I shoudl still have another set of them somewhere so I don't have to hack up delta tripper or crazybike2 for them. But I'm curious to see how well USS works for me, as I wnated to use that in the first 'bent, ReCycle, that I never finished, back before I did any of these other ebikes. I may even use the actual bars I made for that bike on this one, if I still have htem.
Motor....still debating on what mtoro to use but want to try out that BLDC powerchair motor first. It's just gotta be at least as good as any of these hubmotors would be for this type of power, and its' WAY easier to mount on the biek to use like this.
Controller...I have a few 12FETs and a couple of 18FETs. I wish I had a sinewave controller, though, so I could make this thing nearly silent.
