t0me said:
Just a quick update on my primary chain mod.
I changed my secondary driven sprocket to a 48 and now I've broken the primary chain twice. Seems the 04b 6mm chain isn't up to it anymore.
Also, its difficult to get in Australia. #25 chain however seems to be available though and is 30% stronger from what I've found spec's wise. So I'll be re-modifying to take that chain (and try to up the ratio a little on the primary).
Just need to find a #25 10mm bore 11t sprocket. TNT don't have them in stock and I haven't had any luck finding one locally yet.
The drive sprockets I've seen use a through pin. Has anyone just modified one like that (tapped those holes) to use grub screws instead? Theoretically I think that'd work? I'd rather not drill through my output shaft if I can avoid it.
Yep, I drilled and tapped the drive sprocket, filed flats on the shaft for the screws to sit against and have had no problems, Try to source "Diamond" #25 chain , best specs of any #25 I could find, If I remember right its availible through combat robot sites.
