I just opened up my CAv 2.3DP to find the throttle output wire soldered into the wrong place. I bought it new from Grin/ebikes.ca a few years ago. The green wire should go to 'Thd' on the pad but its soldered to 'ThO'. I Think i remember there being a recall on the 2.3 due to possible run away throttle and was wondering if this was the reason.
Anyway, the reason for posting this....
I want to wire up 'current' throttle by using the CA potentiometer, for example, wiring the bikes throttle signal wire to the POT and then having the green CA wire on the ThO(already done, as stated above) and then out to the controller.
Can someone check this photo and tell me whether the +5v and the POT are meant to stay bridged like this when i add the bike throttle signal wire to it?
