Raphael303
- Joined
- May 31, 2016
- Messages
- 38
Hi
I have bought a new PhaseRunner (WP8 and L1019), hooked it up, Autotuned it in the software suite, setup works normal, but the CA3 does not get the Speedometer signal from it. Speed shows 0 at all times.
My CA3 has a retrofitted WP8-Plug, so I tripple checked the wiring right down to the "SP" Pad in the PCB of the CA3 (I opened it). It is definitly hooked up correctly, the speed signal goes where it has to go on the WP8 plug. Also quadruple checked that I'm not looking at the plug mirrored.
When I measure the voltage on the SP Pad I get 0 Volt. When I turn the wheel by hand I get nothing either. When I use the throttle to spin the wheel I get a continuous voltage proportional to throttle. Since the wheel is spinning freely I couldn't test it too much, but it never went up to 1V.
In the PhaseRunner suite I can see the RPM displayed live. It is set to Hall-Sensor mode. The motor is a Crystalyte Crown TC3080. I can spin the motor with throttle and it also reacts to torque input while riding the bike, however with far too little power. Which could be related to the CA3 not reading any rpm and speed.
I have attached my settings files to this post.
I connected and checked wiring according to the pix bellow.
Any help is appreciated.
SOLVED
The white wire "speedometer signal" that goes to the Phaserunner/Baserunner L1019 plug need to be paralleled with one of the hall signals if your motor does not provide a speedometer signal.
The hall signals alone are not enough. Even though the PR/BR know the speed, they will not send it to the CA3, also not if you set "HDQ replicating HALL" in the custom parameters. The speed signal that goes to the CA3 from the PR/BR is the speedsignal that goes TO the PR/BR. So you need to provide this.
SOLVED
