MadRhino said:You would need a thousand pound and a freaking steep slope to stall a big DD hub fed 20 kw. :
Mine digs the ground throwing 4 inch rocks 50 ft behind, then spins off its tire when I try climbing too steep.
Your ‘pie in the sky’ is redundant old sh*t already. You find that everywhere on ES for a decade. The receipt is simple and well described in so many building threads. You need a big DD hub motor around 30 lbs, a powerful controller that feeds +200 A, a dozen bricks of quality RC lipo, and a good bike to fit them on.AHicks said:MadRhino said:You would need a thousand pound and a freaking steep slope to stall a big DD hub fed 20 kw. :
Maybe some details about the bike you are thinking of, with some details regarding "your bike" to provide some relevance?
Otherwise, it sounds like a lot of pie in the sky....
MadRhino said:You find that everywhere on ES for a decade. The receipt is simple and well described in so many building threads. You need a big DD hub motor around 30 lbs, a powerful controller that feeds +200 A, a dozen bricks of quality RC lipo, and a good bike to fit them on.AHicks said:MadRhino said:You would need a thousand pound and a freaking steep slope to stall a big DD hub fed 20 kw. :
AHicks said:My point is, bad or misleading information is often worse than none.
scm007 said:So, without weights how is it that the user will be able to generate electricity via a motor while maintaining the feel of say 200 pounds worth of weight? I don't see how this is possible.
You can look up "dynamometer" or "dyno" projects, to see how a motor is used to put a specific load on another motor (or in your case, on a person's input into the machine).scm007 said:So, without weights how is it that the user will be able to generate electricity via a motor while maintaining the feel of say 200 pounds worth of weight? I don't see how this is possible.
