I am a new member but I have already been making my own battery packs. I am currently building a new battery pack for my 500W 48V hub motor.
I have an old battery pack probably 3 years old from a Chinese electric scooter that was given to me. This electric scooter was never used and I planned to use its battery pack for my new E-Bike project. I tested this old battery pack and it reads 51 Volts, so I assumed it is still good. I even tested it with the hub motor and it works fine. I began to open the battery pack because I intended to change the enclosure in place of a custom fiberglass enclosure. But upon opening, I notice that there is no BMS or any circuit present for battery protection. The battery terminals is wired directly to the negative and positive side of the pack.
I can install a BMS, however, I cannot identify what chemistry the cells in this battery pack. The battery pack has 5 parallel cells and 14 series cells. The dimensions of one cell is 26mm diameter and a height of 65mm. Some of the cells has a label indicating "AZ-0531" while some has label indicating "AZ-0622". My only assumption is that it is 26650 cells.
My problem is that I can't identify the chemistry if weather it is LiFePo4 or Li-ion because BMS for LiFePo4 or Li-ion has different min/max cut-off voltages and I have to use the right one.
Is there a way or a method to determine battery chemistry?
Can I still use the cells of this never used 3 year old battery pack which ever chemistry it is?
I have in my shop a 16S LiFePo4 BMS and I plan to use this. Of course I will have to rearrange the cells to have 4 parallel and 16 series. This means I will have 6 cells spare.
