William Knox
10 µW
- Joined
- Jun 17, 2015
- Messages
- 5
I have a battery that lost half its charge, it holds the same power but simply stops working at the 50% charge. I suspect half of the cells are destroyed somehow due to going up a really steep hill after a long ride, I still don't really know why. Nonetheless, I was sent a new battery from my scooter company as it was covered under the warranty, and they didn't ask for the old one back.
Long story short, with the new battery replaced, I retrofitted the old "1/2 capacity battery" into a charging pack by attaching a appropriately rated cable and plug to it.
With this pack plugged into the scooters charging port, I end up getting the extra range that I expected, which seems like a success.
Should I be worried about damaging my batteries, my BMS, controller, or other components? I make sure to never have the pack plugged in if the charge between the two batteries are far off, so I make sure that they are both at full capacity.
Again, the battery specs are identical, they are for the new E-twow Booster GT, they are both rated at 48v with 10.5Ah. FYI: The provided wall charger outputs 48V at 3.0A.
Any feedback would be greatly appreciated.
