chuyskywalker
While I'm working on my torque arm extension, part of the setup is replicating the rear wheel IS Mount (aka I.S. Mount / International Standard Mount / ISO Mount / forum-search-term-stuffing) on the extension arm.
However, in both this design and the previous version, the mounts seem to work with 160mm adapters, but the 203mm adapter doesn't get the caliper in the right spot.
Above, with the 160 rotor and adapter, everything lines up very nicely:
However, when you go with the 203 adapter, it's completely misaligned:
I'm designing the mount points from this diagram, which I've found referenced quite a few places:
And using a few models (caliper, 203 adapter, 160 adapter) for the 3d simulation.
What am I missing as to why this goes out of alignment?
