system
DIY Mundo Yuba Cargo
BMC V3 1000W rear hub
48 V Battery 15 ah
12 fet lyen controller.... not sure on the amps
CA V3 and throttle and three setting switch from you guys as well.
I do not run anything else
I can not figure out why I am getting absolutely no power on hills, luckily I pretty much use this beast to run errands with the kids on a flat 10 mile round trip bike path.
I have the 3 setting switch set to limit the speed 1 at 15 mph, 2 at 25 mph, 3 at 33mph.
I messed with the amps and wattage for each setting to eliminate throttle cutting in and out since I pedal 100 percent of the time .
any tips appreciated ! I have been through and used the suggestions to set the throttle input and output min and max..... but the throttle always seemed smooth one I increased the power parameters for each speed setting.
Donny
I have gone through the manual posted on endless sphere but didn't see or understand anything on setting up the power perimeters for my 3 setting switch. As far as climbing power issues.... I just do not want to mess around with the Amp and Wattage since my experience is more to with mechanics and not electrical.... but I am learning slowly and really appreciated the posted CA V3 manual on walking me through the set up so far.
Not sure that's the issue anyways, any tips appreciated. I guess since this hub has a "clutch" that might be something to check as well.
Donny
48 V Battery 15 ah
Donny
Donny
