johnrobholmes
Can't believe I missed this thread! What a nice build, all around! I wonder what else you have in store for us?
gestalt said:Now the only thing holding me back from putting the frame together in its final form is to figure out my belt drive system as I cant place the motor mount until I know how much space there needs to be between the axle and the motor shaft for the belt to fit. If anyone has any advice for getting my hands on a pulley system that can give me a 5:1 ratio and handle a shit ton of torque please let me know
gestalt said:"hey, have you heard of an australian builder who goes by the name of aussiejester?". Dude, you've got some fame.
gestalt said:do you think 5mm will cut it? someone was telling me I should use 14mm pitch.
Miles said:If it's over 15Nm at the motor shaft, it will need to be an 8mm pitch synchro belt, I think.
gestalt said:what do you mean by relief cuts? The spacer is in the a "C" shape, and I made the gap about 5/16", the compression is pretty damn solid but you cant see the cut in the spacer in the pictures I took. I really can't wait to see what the performance is like in comparison to those mars brushless units, did you ever get yours opened up for pictures?
gestalt said:but here are the specs on how much torque my motor concievably will put out.
5:1 reduction = 50mph, max torque@wheel approx 75Nm, a forward force of around 23Kg (approx 51lbs)
gestalt said:/progress!
//clinical exhaustion!
