bdc43
Greetings!
Well, after much "lurking", I finally decided to take the plunge and join the forum. I've been interested in electric bikes for about a year now and have been doing quite a bit of research online (not to mention watching all the Doctor Bass videos I could find on Youtube! :lol: ) Seeing as the hands on approach is the best way of learning, I would like to do a conversion myself. I have an old 1985 CCM Brutus 6-speed mountain bike that I haven't ridden in about 16 years due to knee problems. I don't have it with me yet, it's still stored in a shed up at my parents' place, but last time I was visiting I took the following measurements to see if a hub motor kit might fit:
Distance between rear dropouts: 5 1/4 "
" " front " : 3 3/4 "
Rims: 23"
I didn't do the "magnet test" so I can't say for sure if the forks are steel or aluminum.
I will probably have to doublecheck these measurements, espcially for the rims, since I can't remember if I measured the inside or outside diameter (like I said, I'm a complete newbie).
Anyway, to give you a better idea of what I have to work with here are some pics of the bike:
(NOTE: In my excitement and haste, I had initially posted these pics to the "E-Vehicles General Discussion" section of the forum under a new thread I titled "Another Total Newbie", instead of here. I asked the Forum Moderator to move the thread here if necessary. Sorry in advance for any duplication of info between the two sections.):
IMG]http://i838.photobucket.com/albums/zz308/bchamb1967/bicycle007.jpg[/IMG]
There doesn't seem to be much rust , if any on the bike, although it's kind of hard to tell under all that dirt and grime.The tires appear to have a bit of rot (as you can tell from the bottom sidewalls in some of the pics) but no bid deal since I would be switching the offroads to a good set of street treads. I should also mention that the cable runnin to the front up is connected to an old mechanical speedometer I bought at Canadian Tire back in the late 80s. The "fannypack" hanging from the handlebars is an "emergency toolkit", also from Canadian Tire (from the style and color, you can probably tell it also was purchased sometime in the late 80s, early 90s. :lol: )
Thanks in advance for any tips/advice!
Rims: 23"
