I was practicing trials on small rocks yesterday, it is actually quite fun when you have enough power to lift the front wheel easy! I practiced balance and wheelies too, I can pull some quite good ones now, like 10-15m long. The motor did hit a rock when trialin, and it seems that the motor support bent a little, decrasing the motor chain tension, making the chain chew rigth through most of the crank sprocket's teeth like if it was plastic 5 minutes later lol!
Once I repair that I will probably do a trial riding video, because I can shot that kind of stuff by myself. Have a new pov cam comming too, wich should make a good helmet cam!
I am seriously considering having the rear and front brake levers inverted, as controlling throttle and rear brake with one hand is quite hard! As said before, I could also try a thumb throttle, may be cheaper then setting up new hydro brake lines!
