Hey guys
Phase runner connected to the CA 3 via 6 pic cable
Problems :
- Regen dosent work
- No speed showing on the CA display
settings:
Regen phase current set up on 70 A
Max regen volatage end 54.5
max regen voltahe start 54.1
Brake voltage starts 0.85 v
Brake voltage max 0.00 v
( the same settings on the CA)
Hall sensors are ok and autotune test done with success
when I run Phase rinner suite software in dash board on the right side I can see Motor RPM and Vehicle Speed and numbers are changing when I run engine
But no km/h shows on the CA 3
Can anybody advise what should I do and where to check that
Thanks Guys !
Lucas
Problems :
- Regen dosent work
settings:
Thanks Guys !
Lucas
