AF7JA
I realize this is more headlight related than e-bike; but it is still going on an ebike.
I have a 36V bottle battery for my ebike. I also have a Magic Shine clone and and a 3V (PDW Danger zone) tail light.
Instead of having several batteries on my bike, all with different chargers, I want to power the other two light from the "main" battery.
My plan is to solder leads from the Bottle Battery case, after the main on/off switch, but before the e-bike controller. Those leads would then go to a pair of voltage regulators, one for the headlight and the other to the tail light (I need two of them because they operate at different voltages).
Does this seem sane? Any concerns (I am an Amateur Extra, I know which end of a soldering iron to hold)?
The voltage regulator
Non-synchronous rectification non-isolated Buck (SEPIC) module.
Input Voltage: DC 4.5-55V; Output Voltage: DC 1.25-30V Adjustable.
Output Current: Rated 2A, Max.3A(need heat sink). If output power is more than 15W, please install heat sink.
Short Circuit Protection: current limiting, since the recovery.
Application: DIY Adjustable Power Supply, DIY Universal Charger, Power supply for electronic equipment etc.
