macribs
- Joined
- Jul 22, 2014
- Messages
- 3,702
Yes the price is steep. But all things considered, no re build of swing arm centralized motor running via gears to give plenty of torque for even the steepest hills it might be worth th extra pennies. After all, those astro motors are pretty much bullet proof. Astro have higher quality magnets and wiring and can take up to 200 degrees celsius of heat. In that drive unit it seems thermal masses has vastly increased so possible even harder to run into over heat issues.
As it stands now he struggles with heat due to operating motor below the most efficient RPM range. He is reluctant to rebuild the swing arm. And he is close to ditching the mid drive for a powerful hub motor. Seeing all effort and dedication spent on this build it would be sad to see him settling for a hub.It just seems that a 3220 drive unit like this will solves all of his problems.
And who knows - if he is lucky maybe he can get one of those test deals - if he is that lucky he can be beta tester for 400$. Might even be possible to work out a way to get the more powerful 3220.
It just seems that a 3220 drive unit like this will solves all of his problems. But hey that is just one mans thoughts. For all I know maybe those 400$ deals are all gone already, and it seems those are not production ready yet for the public.
That being said I am sure it will be well worth it to do a rebuild of swing arm to fit 120 pro. That motor packs a mean punch.
