mvadventure
- Joined
- May 2, 2007
- Messages
- 419
OK, here's the deal. I'm confused AGAIN. Zane of Aten Energy sent me a replacement charger for my 48V 20 AH pack as the BMS built into the battery died. The new charger is three times the size of the old one and LOTS of lights and a big fan. It also has lots of wires. LOTS of wires.
On my batteries and in the pics I've seen of others the terminals on the cells are hollow threaded aluminum. They have a nut over the outside that takes a 17MM wrench and a straight screw down the middle for fastening wires. When my batteries were new and the BMS installed the installer must have been related to King Kong as the screws were in REALLY tight. So tight they when I attempted to unscrew them (32 of them) most of them broke. This left me with a threaded post with the aforementioned 17 mm nut on them. This would have been fine had the new BMS which is built into the charger had connectors that would fit over those said threaded posts that were in reality about 1/2" in diameter. Naturally they had connectors designed to fit with the much smaller screws which were not broken and lying on my bench.
Since I wasn't really thinking ahead and since the hardware store where they sell washers is about 5.6 miles away and I had already broken all the screws and removed all the nuts from all the terminals and had merely a pile of broken screws and aluminum nuts and a LOT of wires with connectors that didn't fit anything and now the bike wouldn't run unless I pedaled it and that wasn't going to happen.
So, I put the nuts on lightly and squeezed the new connectors under the nuts and then tightened them for a friction fit I got everything working. It took awhile but my shop was cool, the stereo had an old Traffic CD playing and except for a nap I didn't have anything else to do. When I turned the key on the watts up meter showed 54 volts which is about normal and since I had been charging without a BMS for about a month I didn't bother checking each cell.
Then the real test. I plugged the new charger in. It lit up like a Christmas tree. There is a run light, a charge light and 16 red LED lights that are individually numbered to each cell. All but two of the lights, 7 & 9 came on for a few seconds and then all went out, the red charge light turned green and the fan quit. All good I figured. I must have done something right.
Then a test run of about 3 miles at 25 - 30 MPH to pull the batteries down. The new charger has an 8 AMP charge rate so I figured it wouldn't take long to bring the battery back and it didn't. After just a few minutes of simply a charge light and an on light the red LED's started coming on and going out. I figured the light indicated almost ready and out meant done. After all the lights went out the charge light which had turned orange when the LED's started coming on turned green.
Then I tested each cell. I went from most at 3.56 volts to a couple at 3.4 and one at 3.6 with a little variance between 3.54 and 3.56. Since Zane didn't answer his cell phone and no instructions came with this new charger and since it had been charging for about a month without a BMS, does anyone know if the cells will stabilize after a few charges/discharges?
The charger is a BCO Lithium Charger, model BCO 4808B and another number that was H20716510G and I couldn't find anything on it using google. Any feedback, pro or con, would be appreciated.
Mike, Crystalyte 5304 with Crystalyte 4840 controller and the LIPO batteries. It now has 2,300 miles on the 5304 and going strong.
