flob
- Joined
- Sep 3, 2021
- Messages
- 41
Hi all,
name is florian and i have been lurking ES since a couple of years,
Now i have build my second e-moto and last year i decided to change from kelly to sevcon...
Its a very long story , dragging on since march and finally since late september i have received a working unit after paying 580 Euros for a repair of a bought new and never working product.
However the vendor did not in the very least program to my specs and of course he does not answer at all again...
So i guess i need to change some parameters myself but i am totally confused about how, i do not want to brick the sevcon.
First things first- the needed changes:
1: under voltage and over battery voltages need changing
2. power cutback treshold needs changing
3. activate(?) regen......see later
4. full power does not come up ( 15 of 32 kw)
5. no full power on start up ( worse than kelly...3kw...then 7 at aprox 30kph...15kw from like 50kph) )
6, how to save the original dcf?
for 3. it seems that regen is programmed (pic) but if i let go of throttle it just rolls to stop
so any idea where it is actually "activated"?
for 1,2
during a single online/ remote desktop session the vendor simply "clicked" away one switch ("ah- you using only 2") and hit "save", so i assume with battery voltages i could be trying the same? ( as there are up/down arrows next to the fields- see pic)
for 4,5
why is there no full power from zero rpm? ideas?
why, it seems i have different torque from first delivery to now?
anyway what could cause the slow accelleration from standstill? any ideas?
where is the point of using a sevcon´s ability to go full power from standstill if it ramps up so slow that even a kelly will outperform it?
Any help apreciated
btw:
this is my bike
flo
for 1,2
for 4,5
Any help apreciated
btw:
this is my bike
flo
